Rear brakes locking up
77broncodriver
Ever since I swapped in my hydro boost my brakes have been awesome other than the backs locking up.
I bought a proportion valve that I haven’t installed yet but read somewhere that they don’t actually restrict the pressure going to the back but only momentarily slow the pressure to the back. It seems like even if I slowly get on the brakes the backs still lock up and the fronts never catch up (not just when I slam on them) You guys know if this is true and if I need something else other than just a proportion valve?
Evan
SteveL
Huge chevy guy
Hawthorne ca
I've always thought the proportioning valve reduces pressure to the rear. Bc sells an lbs valve that takes the initial spike from the rear on a panic stop. On my 66 I have the lbs valve. With the vacuum booster the rears never locked. After going hydro boost the rears will lock but it's somewhat controllable. Currently swapping hydro boost onto my 72 with same setup(4wheel disc with lbs). On the 72 I'm gonna add a proportioning valve to fine tune it. If it's a noticeable difference I'll be adding one on the 66.
garberz
Bronco Influencer
Conejo Valley, Ca.
I use the Wilwood adjustable valve, plumbed to the rears only. It reduces pressure up to 57%. I’ve used this valve on several hydro boost installs with great success.
Mark
77broncodriver
77broncodriver
Thanks for the info guys!
That proportion valve is the same one I got I believe. Looks like I have a project for the weekend now.
Apogee
If the adjustable proportioning valve doesn't solve your issue, but does help, then the other thing you can do would be to increase your front brake bias. You can do that by running a larger front caliper piston area, commonly referred to as a big-caliper upgrade with either Chevy or Ford disc brakes. This effectively reduces the pressure required to achieve front lockup, so less pressure is supplied to the rear brakes as well. Alternatively, you can run a more aggressive, higher CoF brake pad up front as well to shift bias forward.
