gravy
After finishing the front coilovers I got the itch to do the rear. Im currently running 4.5 front coils and adjustable shocks with 4link. It works great but coilovers was in the plans from the start. I have the protofab rear shock hoops with the body cut outs so I am using that space to mount my hoops and then run a cross bar through the body that is removable. I got another set of Rock Krawler 14 travel 2 5/8 coilovers from Ken and JK lower coilover mounts that I will be using upper and lower. The coilovers will be mounted slightly forward of the rear axle with a slight angle forward attached to the upper mounts. I am using 1 3/4 120 wall tubing. Pics show the hoops in progress along with the modified RK mount and finally the trussing. Next is to get them mounted in the truck- more to come.
