fire bronc
Alright,the Question Is I Had The Rearend Rebuilt, New Gears, Trutrack,i Put The Thrid Member In The Housing Bolted Up,put My Drum Back Plates On And Slid The Axels In The Housing The Axel Went In Pretty Easy Got About Half The Bearing In The Housing,due To Me Painting The Housing And Paint Build Up I Had To Pound The Axel In With A Rubber Mallet The Rest Of The Way,got Axel In All The Way Tighten Down Bolts,and Tried To Turn Axel Without Tire On And I Cannot,i Tried To Turn By The Yoke And Can Just Barely Turn,there Is No Fluid In Yet But I Have Never Seen One This Tight To Turn (1)is This Because Of The Tru Trac (2) Is Something Not Set Right.i Had 4.30 Gears Put In,, Detroit Tru Trac You Could Spin Free With The Third Member Out. Help ****
