rebuild manual/steps for a stock p/s box?
RnrdTheFox
Superior, CO
Does anyone know where I can get a detailed steps for rebuilding a stock p/s box online? I'm getting the kit tomorrow and would like to have a step by step procedure.
Thanks.
turbotim2
____________
I have some .pdfs that show it really well. I just rebuilt mine and it was quite easy. Did you get the kit ffrom Jeff's?
turbotim2
____________
Go to this website - http://www.chevelles.com/techref/shea_2.html and download and print the 6 pages. The instructions that come with the kit are not for Broncos. Also, the "special tool" shown on there you don't really need. I used a 1/4" drive, 7/16" (I think, maybe 3/8") deep socket with an extension to seat the balls. Careful when you remove the screw, there are 22 ball bearings in there that will fall out.
RnrdTheFox
RnrdTheFox
Superior, CO
Thanks! That's what I was looking for. I got my kit from Napa. It's only the seals etc... The box seems to be thight and only needs a few seals to stop the leaking. Thanks again.
turbotim2
____________
Oh ok. Just so you know, the two thrust bearings and the input shaft bearing don't seem to be available anymore. The two sector shaft bearings are available.
RnrdTheFox
RnrdTheFox
Superior, CO
Do you have the PN for the two that are available? I should replace those while I"m at it. Does the JB kit have anything extra in it? Thanks.
turbotim2
____________
It had the sector shaft bearings in it, the teflon rings, seals, washers, snap rings, lock nut... I don't have the number with me right here, the two are the same bearing number. Also, when you remove the top plate over the sector shaft, there is a metal gasket with a rubber seal that you will probably have to reuse so make sure you are careful with that one.
