What would cause my ballast resistor to get red hot and quit working?
I've got the DurasparkII ignition module and distributor , MSD BlasterII coil , a virtually new HD voltage reg , and a Painless wiring harness.
I've got the ballast resistor because the Painless doesn't have a resistor wire in the run circuit - and MSD says if you don't have the resistor wire you need the ballast resistor to prevent burning up the coil. - nothing to do with points ignition .
Soo- it wouldn't start , i looked under the hood and the ballast resistor was glowing red . After i let it cool down the engine wouldn't start so i bypassed the resistor and it started and ran . But the coil started getting pretty warm so i shut er down.
What would/could cause that? -- bad -- voltage reg , coil , ignition module , bad resistor , something in the "magnetic pickup" in the dizzy?
I'm going to replace the resistor ; i just didn't want to fry that one too.
SHX
Oh - do they make an internally resited coil - and what would it be ?
SHX
