Removing gear shifter on Auto column
Izzy
Texas
How do you remove the gear shifter on a automatic column?
I need to take the dash off but can figure out how to remove the shifter.
Thank you
half cab
Guru Bronco
WOW I was doin this same thing and went to drive the pin out at the base of the lever and had to stop I thought I was gonna brake the plastic shift selector off (PRND21)I guess because it (roll pin)had never been out?
Izzy
Izzy
Texas
So just tap the pin out? Can I tap it out either way or does it only go one way?
bigjhoov
nobody
If it's a stock pin it should be tapered to come out one way I think. Should be knurled on one end and that keeps it in place.
bc1974
Just put mine in and it went in from the bottom so I would say it would be safe to come out the bottom
Izzy
Izzy
Texas
Hey guys, been working in the garage all day. Yes, we did finally get it out. Had to soak in pbblaster for several hours and then bang the crap out of it and it finally came loose.
Thanks for the help guys.
fetorino
Orange, CA
What a bummer
The roll pin in mine came out with a couple taps on a punch. At least you got it out. Pulling the dash was more of a PITA then I thought it would be. Those screws under the windshield were the bitch for me.
Izzy
Izzy
Texas
Lucky for me, those screws where not in mine :)
