Start by removing the arm rest/door handle and window cranks. I think either a 7/16 or 3/8 socket for the arm rest, a 5/16 or so socket on the inner door handle, just a Phillips screw driver for the window crank handle. Remove all of that and the the trim from the inside of the door. Mine is just metal and has lots of screws around the outside. Other years may need a trim removal tool for trim clips. Either way the window glass comes out from there. Down from the bottom, just loosen the track and it will come out, the vent window may need to come out also before the window glass will come out. The outer handle has a screw on the back side of the door and maybe a couple of nuts inside the door. You will have to remove the anti rattlers also. Very easy job, hope that points you in a direction.
