Bronco Sport
I've been reading through the archieves and have a question about the rear posts. Are these welded in on all years or did Ford make any EB's with ones that unbolt?
evil69 said:They unbolt. There are I think four bolts on each post. Unbolt the ones from the truck itself, and lift very high and leave them on the top.
feitctaj said:Dam those are tiny little eyes coming out of the drywall and holding all that weight. You don't mind having that top mounted on the fenders, hood and ws Frame?
I am scared for you:'(
Bronco Sport said:.......I weight 225lbs and hung from one of the eye bolts without any problem.
Fathom said:Sound Kinky!
and a little to much information and now I scared!
I think you may be OK, they just look tiny and I be an overkill guyBronco Sport said:I know they do look small from the angle in the picture, but they do have the weight spread across all four points with the 2x4's. I do plan on adding one more 2x4 and anchoring it so I will have six locations. Does anyone know the actual weight of the hard top? I figure it can't be much more the 400lbs, please correct me if I'm wrong. So, with six points the load would be less than 65lbs per point. I weight 225lbs and hung from one of the eye bolts without any problem.
