Removing outside door handle Help!
HigginsHorse
I'm trying to remove my outside door handle. I have removed both of the screws but I can't seem to budge the rod that connects the door handle and the door latch. Can anyone tell me if there is a trick to removing it. The rod appears to have a plastic sleeve on it that also goes through the door handle. The rod looks like it just slides out, but its not sliding.
Help!
HigginsHorse
Blue71
Liie Jeepster said. Flip the little sleeve. I usually use a small skinny flathead screwdriver to pry under the edge of the sleeve and flip it.
Good Luck,
Blue71
