First of all, those are studs and I wouldn't take them out at all. Clean 'em up and chase the threads with a die if you need to but don't take them out. Then, as DJ said above, soak the broken one with PB blaster or Mouse Milk. If you can't get the broken one out with an easy out then you'll need to gradually step drill up until it will come out. I've actually drilled em until you could almost peel them out. Here's the deal though. If you have to keep drilling, make sure you drill down the dead center, 90 degrees (perpendicular) to the surface. Even if you have to drill out the threads you can fix it with a helicoil. If you've never used one, with a helicoil you oversize the hole, tap it, and insert a coil that looks much like a spring that brings the hole back down to the original size and threadpitch. You can get them at the NAPA store or Fastenal. We use them to repair threads in aircraft engines all the time. I used one to repair the threads in a 302 rear main bearing bolt hole before and then put another 100k miles on the motor. There are lots of videos on youtube that will show you how to install them. Good luck!
