Techstudent
Greetings!
I pulled the original fuel tank and brought it to a local radiator shop for cleaning. They started soaking it and found it to be leaking.
I would like to purchase a simple replacement steel tank (the same capacity is fine). Wondering if you might suggest a good quality replacement. I see several options: Rock Auto has a Liland Global Tank at $220.00. The Wild Horses setup with new strap, fuel filler hose and sending unit runs $245.00.
Other options?
Any differences In steel quality on these vendor tanks?
Thanks for help/suggestions!
Other options?
