I think I have the line on a replacement mirror glass. It's from K-Source part number 99145 and can be had from a couple sources like O'Reilly's. It measures 4" x 5-3/8" and diagonal is 6-3/16.
Here is a linky: http://www.oreillyauto.com/site/c/d...ck=Search_02608_1120723_-1&pt=02608&ppt=C0329
However, the mirror I have matches all dimensions but instead of 4" it's 4-1/8" I'm thinking that it should still fit. Mirror I have is off a 67 Galaxy, C7AB-17743-A....I'm pretty darn sure it's the same mirror as the Bronco. Anyone try using this replacement glass?
I think it will work great as I can split the 1/8" between the bottom and the top.
What do you think?
Thanks,
Mike
What do you think?
Thanks,
Mike
