CrazyHorse
hello everyone! my 77 needs a chp inspection here in california and I am needing a few things for it to pass.the only one I cant find is a reverse light switch for the old Duffy 3 speed on the floor shifter. The original under the hood on the steering column broke so I cant make a bracket to make it work under the tunnel cover because it's too fragile(plastic). I need a steel one or one made for the shifter. I called Duffs and they dont carry it and the local speed shops dont as well. Do any of you know where to get one? I know the knew shifters are Hurst but were the old as well?Duffs didnt seem to have any info. The lights MUST come on when shifted into reverse or it will not pass. so a button on the dash won't cut it. Thanks ahead for any advice.
