Rocker and Door Post alignment question
hawkgt
Leesburg, VA
So far I have replaced the front inner fender, kick panel and door post. I am at the point of putting the rocker on and I have a question about alignment between the rocker and door post. At the bottom of the door post the halves of the post are split. Does the rocker go on the far rearward side of the entire door post or does it go in between the split in the rocker? Pictures can be seen HERE and HERE
Thanks!
Jason
2badrotties
Just a Bronco guy !
Niskayuna N.Y.
Hard to see your picture even when I click on it and make it bigger. When your rocker is installed there is a small space for the fender to slide into. That small slit needs to be there for the fender to fit into. There isn't much else that holds the fender in place down in that area besides that small brace on the bottom of kick panel. I think that answers your question. :)
