Airmapper
Foolproofness Tester
I need to think about my 70 Bronco's safety a bit more. I'm hoping (or at least having a bad case of wishful thinking) that it will be drivable this summer. I'm looking for some input on what is out there that might suit my needs and situation best.
I currently have a basic 4 point roll bar that was in it when I bought it. Each corner is held by one bolt to the rotted floor pan. So, it's just holding my Bikini top up.
What I would like is a family cage. While I'm not even sure if I'll keep the rear seat, I may use it one day. I'd also like to have a roof rack, so a full family cage gives me more options.
I do not have a welder at home. So my fabrication ability is very limited. An option I am keeping in mind is buying a welder and a weld it yourself kit, not sure if I will get a welder soon or not, but it's a need for this and any other fab project to come.
I looked at BC Bronco's roll bar. My favorite features are the utilization of the body mount locations, and the bars running over the frame rails, pretty much trapping it from punching through the floor pans without needing to weld mounts to the frame.
But, I think the BC bar is ugly. The design grew on me and while it isn't my favorite aesthetically, I definitely like it's ability to be a "bolt on" option. The problem with it is, I'm going to be running a gear banger shifter, which will interfere with the A pillar, a feature I'm not that crazy about regardless, but looks somewhat necessary for better support. So it's not a 100% solution.
I also have a concern about not crossing up my seat mounting and seat belt mounting to different structures. I was hoping I would not have to buy all new seats and such as well, but I do need at minimum shoulder belts. I need to be careful not to set myself up to be ripped in half.
Thanks for any ideas, maybe you guys can suggest how to combine some of my ideas into something that I can actually use.
