There is a lot more to this subject than room to detail here. Just a couple points on spline theory. A spline is nothing more than a half-depth gear tooth. The tooth form is involute, same as a gear. Advantage of the involute form is, regardless of clearance (backlash) the male and female spline members will self center under load. There are three common pressure angles used in involute spline design, 30, 37.5 and 45 degrees. For sake of simplicity, the pressure angle defines the slope of the tooth. Picture if you will, a male and female spline members engaged and under load. If 45 deg PA, the tooth face of the female member will be experiencing a force vector equally tangental and radial. This radial force component generates a significant bursting load that can result in failure in thin walled parts. A more tangental force load is always prefered. So here's the point, rolled splines are typically 45 deg PA. The process really can't generate an accurate 30 deg PA. 37.5 deg PA is considered a bastard compromise and is the least common of the 3 PAs. In conclusion, if designing for strength, use 30 deg PA and hob the external spline, if for mass production roll the splines and design for radial loading.
