Jsp
rossette welds broken and tube wobles Dana 44
Ok so i,m in the middle of narrowing a 78 bronco dana 44. I don't believe the welds were broken till i started pounding. it was a pain in the but to get the casting end off even with heat. i ended up damaging the mount for track bar really bad. had to cut it off. LOL figure i'll weld on a riser like wildhorse sells. anyway once i pounded the cast end back on i notice the tube wobbling in the axle housing it looks like the welds are cracked. had to use a small sledge and block of wood with axle standing up on grass to get it back on. I have no problem rewelding these and welding up the tubes but is it an issue that is not a perfectly tight fit? i thought these were pressed in.
