oldiron
- Jul 21, 2005
- 1,032
As I'm digging deeper into the efi swap for the '77 (Mustang SD EFI). I've had an idea. The '77 is running an '86 ho roller, so has the ho/351 firing order, everything should match up nicely and run great. BUUUT in my '72 I'm running a '68 302 with the old non ho firing order. It has been my understanding that you could run sefi on this engine and it would run fine but could have a small idle problem due to the different firing order. COULD I use the harness and ecm from say an '88 crown vic/grand marquis that used the old firing order? So far I haven't found a reason why it wouldn't work just fine. I did an inventory yesterday and I believe all I'm missing is the ecm for the swap.
BTW the '77 efi swap hasn't been nearly as hard as I thought it would be so far.
Greg
Greg
