Rust Bullet/POR-15
CrazyHorse72
Pennsville, N.J.
Are there any other options out there other than rust bullet or por 15 with the same general concept. Getting ready to do my frame and can't decide between the 2. Or do I even know if there are any other options. Any advice or insight would be greatly appreciated!
Mark
Bronco Klutz
NW Indiana
I think Rustbullet sucks :p
I've had excellent results with POR15.
I've read where the two work on the same principle, my results say something is different between the two, something significant!
74bronc
I just used Eastwood's rust encapsulator on my inner quarters and rear fender wells and it is fantastic. same price as rust bullet. Dries flat black, one step process like Rust Bullet but not that butt ugly silver color that requires a top coat to look halfway decent. .02
Skipdevil
San Diego
Check this product out: http://www.zerorust.com/
I used it to undercoat my tub, frame and engine compartment. It was easy to apply either with a brush or spray. Just make sure you clean the surface well for oil, grease, dirt and loose rust scale. There is no need to strip it down to metal. I like it because it adhears to other paints and is easy to touch up if you scratch it. It comes in different colors too.
Skipdevil
