[quote author=Wzbell link=board=5;threadid=10764;start=0#78710 date=1036031551]<br>After removing both fenders today to replace them some time in the future I found both door posts are rusted. One more than the other. the worse is rusted out up past the bottom hinge in the inside behind the fender. I assume the posts are fine as lomg as they still hold the door solid with no sag or sway and that I treat the rust. Should I metion I am not restoring to mint or stock just somehting i can have some fun with.<br>[/quote]<br><br><br>The rust will only get worse. I would think about buying the new posts from JBG as money permits. I replaced the front driver side post 3 weeks ago on my 77 and the door post from JBG was an excellent fit needing only minor trimming at the top of the post. This is one of the main support structures for the dash, door and kick panel area. Check out the links in this site and remember to take good measurements from the rear post prior to cutting out the old post, and only cut one side out at a time so you can use the other side as a guide if possible. ;D
