You guys useing Ryans harness,,, are you splicing the one power lead for both high and low pressure pumps or are you useing a different power source ??
The one lead just looks a little thin,,do these pumps draw much power??
His directions state its OK to split. I think they also said you can up the size of the fuse to 30amp too maybe if needed. Should be fine, but I'm running an in tank pump so dont know from experience. SB
I ran the main wire to the first pump and then ran a jumper from the first pump to the second pump. seemed to work well enough for me till I went to the intank pump.
You are connecting those just to the relay, right? The "power" to each pump should come direct from battery , and the harness supply only "trigger" to a relay.
The lead is almost long enough to go to the back of the Bronco. In the directions it says to hook the pump to it (just the lead ) or to splice it if your useing two pumps. I assumed if Ryan wanted you to use a relay it would be stated .
I just wanted to make sure nobody had a issue doing this .
Just to feel better in the future I probably will use a relay ,,,might be nearer in the future than farther.
