Saginaw Pump Benefits
Mikey
I have a 79 Ford Van that I pulled the Saginaw pump , hoses and brackets off of to eventually replace my stock pump. Question is, I have 31s and the stock pump seems fine so far so,what are the benefits of a Saginaw pump over a stock pump with the smaller tires? ?:? Is it only a big tire-type benefit?
I've heard the Sag is more durable, does it deliver more pressure? Will that blow seals, then?
Thanks,
Mike
M
Mikey
Yeah, I am cleaning it up and painting it to use. I was thinking, I'd do the swap when the stock pump dies....unless there is a good reason to make the swap now.
TOFIC
Bronco Wrencher and Fixer
Redcliff Alberta
Yea one big reason NO pump whine!! nothing more annoying than the Ford power steering pump whine.
TOFIC
M
Mikey
Ahhh...but ya always know it's a Ford without looking!
RajinCajun
HawleyTX, La orig.
Exactly... that whine is why I just ordered the bracket from BC Broncos, mine works now with an open front, but a Detroit is on the way :), and the stock pump won't last long I am willing to bet..
z70what
Johnson City
if you're thinking of doing it, i'd just go ahead and do it... you won't regret the Saginaw pump and you can get one from O'reilly's w/ a lifetime warranty for like 75 bucks
Luke
M
Mikey
...or a free one off my parts van that was working fine!
Pa PITT
Stephenville TEXAS
Use the free one 1st I pulled mine off and old dodge tr .that had set for about 10 years I pulled it as a pattern when I was trying to build my homemade bracket ..well long and short it still on after about 2 years ...
I LOVE FREE...
