I have a couple of mid 70's Scout II's and noticed that the power steering box is identical to the early bronco except for the 3 hole bolt pattern (the scout has the 2 holes on the opposite side) I tapped my 72 Bronco for the 2 new holes and welded up a support bracket for added stength and she fit right in. My drop pitman arm worked just fine as did the EB power steering hoses. I am running the EB factory pump. I considered using the Scout saginaw style, but didn't have the time to check to bracket fit on my fuel injection.
Just thought i would share this with everyone, as everyone is aware of the couple of hundred bucks you can drop on an EB gear box.
Adam
Adam
