I thought about trying that myself but it doesn't look like I can get it moved back far enough, what pitman arm are you using and does it work well?
I Called West Texas Offroad, There was nobody there at the time who know the answer, they are supposed to call my back.
Well, there are trade offs. It is moved back so that one of the bolts is inside the little cross member angle bracket. I'm using standard EB pitman arm, but it is pointed forward.
It puts a pretty good angle on the tierod, so I'm running the performance unlimited heim steering setup. that has the draglink pushing on the knuckle. With stock setups I could bend tierods without much effort.
It works fine. I can see scuff marks on the pitman from where I've bouced it off rocks from time to time, but I never noticed while driving.
The good part about this is that with the Pitman in front, most of the turning stress is on the front 2 bolts, If you reverse this box more stress is on the one bolt in back. ( that's why the stock EB has 2 bolts in back).
Two other "good" points are that because the box is mounted close to the cross member, the frame flexes less than the stock EB.
Also, since the box is mounted further back, you have more room to put an aftermarket radiator ontop of the frame rails ( if you wanted to).
The bad is that you have to use a heim steering setup or you will bend tierods off road, and you need a custom length draglink or you won't have the right turning radius ( mine is ~ 8 inches shorter than the EB)
This box was on it when I bought it. The PO had cut out a section of the frame and welded nuts inside the frame and the box just bolted to the one side of the frame. That worked ok until I did the rubicon and it started peeling the plate away from the frame.
I think it would be possible to just put the front 2 bolts through the frame and use the nut inside the frame on the rear bolt because of how the stresses work. The rear bolt gets pushed in rather than pulled out.
If you do this you MUST put some peices of pipe inside the frame for the bolts to go inside of as they pass through the frame, otherwise you collapse the frame as the steering pushes back and forth.
I put some pictures in my gallery
Tom
