Phil76
Okay, so we got her running a couple weeks ago, but have been having issues of rough idle, dies when in motion, etc. The plugs are pretty black, telling me either a rich state exists, or there's something wrong ignition wise. I'm leaning toward the choke not opening all the way for some reason, causing too much fuel to enter,and foul the plugs, and make things rich. I purchased a long block which is a 1980-up, with one 78 head, and one 87 head, hydraulic lifters and unknown camshaft. I pulled the distributor from my 74, added a 40,000 volt coil, and MSD wires. My main question is: what should my spark plug gap be? I've read anywhere from .30-.50. What should I base this off of, the distributor, or the engine? Also, what is the ideal point gap? I have an Edelbrock 1406 which we rebuilt, and know this is the main culprit behind my issues. I want to make sure once I get that fixed, everything else will be good. One final item: it has the dual vacuum advance, but no valve installed in the thermostat. Should I plug the outlet closest to the distributor, or leave it open? Thanks
