Started rebuilding my 77 A/T steering column and undoing all the jackleg crap the PO did when he pulled it for painting. My biggest problem was he put the spring/plunger assembly for the shift lever in so unbelievably wrong I can’t believe he got it back together and that it even shifted. There are 2 screws that hold the spring/plunger assembly in place. PO used what I believe to be at least 1 of the original screws and another that is obviously wrong and broken off in the housing requiring a new housing. The screw that appears original is .138 dia across the threads which is #6 and .330 long. #6 screws come 32 threads per inch but this one is much coarser than that and also appears to be slightly tapered. It is oem #41540-S (U-353). I’ve had no luck finding these so far. Does anyone have these screws or know where I can get them?
