joshd1971bronco
I've done a lot of metal work to the tub - replaced floor pans, bed section, inner and outer rocker, etc. I've had the tub braced well the whole time - we all know how flimsy they are.
It appears, now that the body is sitting back down on the frame - on the body mounts I am running (1-inch body lift from WH) that the tub needs shimmed. I say this because the door openings appeared to be 'pulled out' or spread apart at the top - the top of the opening is wider than the bottom and when fitting the door this is apparent. Furthermore, it felt like when I sat the tub on the frame and started bolting it down I was pulling down the front and rear body mounts - sort of sucking them down as I got it tighter - which would spread the door opening a bit.
So, it seems I could shim (somehow) the front and rear body mount locations to try and get things as straight as possible - paying attention of course to body lines and such. Is that okay? Is that typical to have to do? It seems like it would be fine. I just want some reassurance.
By the way, I am running different doors and such so I can't comment on the condition before vs. after. It just 'is what it is' right now.
Thanks for any insight.
