red67
My truck has been giving me trouble, and I believe it is ignition related. It died twice on me tonight after hitting good size bumps in the road, and it also failed to start immediatly after being parked for an hour or so. I think Ive narrowed the problem to a loose connection at the coil.
I have a MSD box, coil, billet dist., and their wires. The blaster 2 coil requires an intermediate unit between the coil wire and the coil itself, and this seems to be the problem since after messing with it the truck will fire up. However, tonight when it failed to fire up I played with the coil and had the hood open. After it started up, I went to shut the hood and noticed sparking and flickering everywhere. The sparking most noticeable was at one of the wires going to the coil, but there was also significant electrical flickering all along the wires from the dist. to the plugs, and bright flickering at the plugs themselves.
Is this normal? I was just wondering if the plug wires should be glowing and sparking and clearly visable at night?
TIA
Ryan Sekula
TIA
Ryan Sekula
