Should I be worried?
Nightstick
Bronco guy
Go to compcams website and enter the part number and see what springs they recommend. Mine is the 35-255-5 I'm nit sure what the grind number is.
ryoungbronco
ryoungbronco
Belmar, NJ
Thanks Nightstick that was exactly what I was looking for. They recommend 340 lbs rate and mine are 360 lbs. I think I should be good to go. It is actually the same springs recommended for your cam too. There is a second choice of a spring closer to 300 but I'm guessing that is for lower rpm engines.
Nightstick
Bronco guy
I think I put the higher ones on mine as well. You lucked out though, I couldn't even get the TFS springs off myself so I had to have an engine shop do it.... Good luck
