JC Whitney has some very small motors that fit in the original holes nicely. They're pretty cheap, and are kind of loud, but they fit perfect and take up no room.
I have them on my 66 Bronco. The PO must have taken the vacume wipers off and exchanged them. not a bad move they dont stick up over the frame. Just have to get a good ground or they may run at different speeds. I run with no top so I don't need them that often. Unless you do alot of mudding. They do move pretty slow. Good luck Galen
There is a link somewhere on wiring them up so they will sycronize . Be sure to plug the old mounting holes by either welding them shut or making a cover plate and sealing it to the frame or you will get moisture inside the frame , which causes rust which is an EB's worst enemy.
