More info needed for smog pump/emissions stuff....
Enclosed is a photo from someone original 75 bronco with the emissions stuff still intact (forgot which user). I have been trying for a long time to get my set up and ready for daily driving in AZ. I think I am close.
first question. I got a new smog pump/thermactor from O'riellys a few years back. The only option was with the air bypass valve that bolted right to the smog pump, unlike to stock one that was remotely connected with rubber hoses. I think that is fine? But this air bypass valve has 2 vacuum nipples on it and the stock one only had one i think, which one do I connect to and do I just plug the other one like I have done in the photo?
Secondly I still have not found the Vacuum differential valve. Does any have the original parts numbers for this one or know where to get it?
Thirdly in the vacuum diagram enclosed, number 12 the vacuum solenoid?? Does any on know what this is? where does it go on the engine? Does anyone know the original part number for it?
Lastly, in the stock photo the one ported vacuum switch has an electrical connection on it, I believe from research this was only from 1975 but what does it connect to electrically? And do i need this if the 76 and 77 did without them? I have found one NOS but the guy wants 140 bucks for it so if I do not need it then great.
Thanks you all for your help.
