stingus
1973 Ford Bronco-Daily Driver
It's killing me to do it but I have another baby on the way and need to get something else. This has been my daily driver and I have put a lot of blood, sweat, and beers into it. I've replaced/fixed everything that needed it.
Please feel free to check all my threads and know that everything addressed has been fixed.
Please take a look at the detailed info listed below as well as the pics posted. The only rust is on the drivers floor pan. The previuos owner Linex'd over it but there is evidence of pitting. The rest of the truck metal/floorpans/ etc.. are great! Body is straight, great paint, all metal etc...
I wanted to put it up here before going to Ebay.
Hard Top w/Tinted Windows (great condition)
Kayline Soft Top-White w/ Tinted Windows(great condition)
Paint and Body in Great Condition-straight body, no dents, no rust, all metal
8 Point Family Roll Cage (Tom's Family Cage)
33 inch BFG's (great tread)
16 inch Centerline Rims
3 Inch Suspension Lift (Tom's Bronco-Stage 4 Lift)
Rebuilt 302 w/ Mild RV Cam
Line-Ex Interior
Leather Reclining Captain's Chairs-(Wild Horses)
Leather Rear Fold and Tumble Seat-(Wild Horses)
Diamond Plate Toolbox- (Mounted Behind Rear Seat)
Sony CD/MP3/Stereo and Sony Speakers w/ IPOD Input
Sony 6 by 9 Speakers-Boxes Built Into Wheelwell
Bronco Steering Wheel (Tom's Bronco)
3 Point Shoulder Seat Belts (original lap seat belts included)
Tuffy Locking Glove Box-(Have Original Glovebox)
Tuffy Locking Console
Rebuilt Steering Box (West Texas Off-road)
Dana 44 w/ Drum-New pads(I have Knuckle Out for Ford Disc Conversion, as well as Hydroboost with Mount and all lines and fittings from PSC)
9" Rear End- 28 spline, Light Duty Axle (drum)
Rebuilt Transmission-completely gone through (November 2011)
3 on the Floor w/ Tom's Shifter
Dana 20 Transfer Case-4 wheel drive works great
Edelbrock 4 Barrel Carb
Edelbrock Intake
Manual Choke
New Pertronix Flamethrower Distributor (August 2011)
New Pertronix 2 Electronic Ignition(2011)
New Alternator(2011)
New Voltage Regulator(2011)
New Coil(2011)
New Clutch and Fly Wheel(less than 1000 miles on it) (August 2011)
New 4 Degree C-Bushings and Radius Arm Bushings(2010)
New Trac Arm Bushings(2011)
New Rear Wheel Cylinders(2011)
Rebuilt Power Steering Box (West Texas Off Road)(2010)
New 23 Gallon Gas Tank w/ New Sending Unit (Tom's Bronco)(2010)
Auxillary Tank and Selector Valve Work- but are disconnected
New Dual Return Power Steering Pump and Pulley(2010)
New Fuel Lines-(2011)
New Fuel Pump and Gasket-(2010)
New Water Pump(2009)
New Solenoid-(2010)
New 180 Degree Thermostat and Gasket(2011)
New Heat Insulating Carb Gasket-prevents heat soak(2011)
New Plugs and Wires -(Nov 2011)
New Heater Core-(2010)
New Chevy Blower Motor and Cage Conversion(2010)
New Cowl Seal (2011)
New Temperature Sending Unit-(2010)
New Oil Pressure Seding Unit-(2010)
New Transfer case Seals-(2010)
New Wheel Seals-(2009)
New Crank Seal-(2010)
New Pinion Seals-(2009)
New Harmonic Balancer (Tom's Bronco Parts-2010)
New V Belts-(2010)
New 3 Groove Aluminum Crank Pulley-(Tom's Bronco Parts 2010)
Alignment Done-(National Tire and Battery 2011)
Tom's Wiper Arms Conversion
Intermittant Wiper Switch Conversion
Maplight Rear View Mirror
New Seals on Fresh Air Vent Box(2010)
2 new 12 V Power Ports(2011)
Parts Included with Sale
Kayline Soft Top and Hardware(great condition, white w/ tinted windows)
Hydroboost w/ Mounting Bracket-Astrovan
Hydroboost Lines and Fittings(Summitt)-New in Box
Ford Knuckle Out For Disc Conversion-
(from 1979 Bronco)
Warn Hubs
Other varios Parts
Line-Ex Interior
Edelbrock Intake
Manual Choke
New Coil(2011)
New Solenoid-(2010)
New V Belts-(2010)
(from 1979 Bronco)
Warn Hubs
Other varios Parts
