This is the HD Saginaw P/S pump upgrade kit sold by WildHorses prior to the version they offer now. I have gone to a serp setup so no longer need it. It worked great, no noises or leaks, and made steering almost effortless. As you can see in the photos, the kit includes two cast brackets that adapt the Saginaw pump to the original Bronco P/S pump bracket. The adapters are mounted to the pump using countersunk socket-head bolts. Pretty slick. Another advantage to this setup is that you can remove the pump from the bracket without removing the pulley. You will get everything pictured: pump, adapters, original pump bracket with hardware, pulley, both hoses and the belt. I probably have less than 1K miles on this pump. My rig is more of a perpetual project and less of a driver. If you look close you will see the paint in the pulley groove is barely worn off. I have not repainted anything in the photos. These hoses were used on an original EB P/S gear so don't know if they will work on an F-150 gear conversion. This whole package is kind of heavy so the shipping cost will be proportional.
