Source for new hub allen screws?
cakedude
Friendswood/houston,
Hello all,
I am looking for a source of new allen/hex screws for locking hubs. I am doing a front disk conversion and had to drill out several that were stripped out by the PO. Any Ideas? BTW, I am in houston.
Thanks ?:?
broncow72
Village Idiot
Spring,TX.
The best source I have found around here is my local Ace hardware. Sounds goofy but they are a REAL hardware store. If they don't have it, they should be able to get it. Since you drilled them out, are you going with heli-coils or larger screws? If you find a good fastener source let me know ;D .
C
cakedude
I was able to drill them out without destroying the lockouts. It was a pain in the ass and took a good bit of time. All I really need are the new allen/hex screws and I should be good to go. The ace hardware here in Friendswood just closed down about a month ago. You're right they did have all kinds of fastners.
INPHOBIC
Kansas City, KS
I know warn sells bolts for thier hubs The warn standard hubs may use the same bolts, I know the premiums use a smaller one. May just have to run down a salvage yard.
Jake
broncnaz
Try you local auto parts stores that carry motorite parts they usually have a row of them motorite makes all the hard to find small parts like door clips, handles, caliper bolt ect. I've seen the hub bolts you need in that isle all the time they usually have the 1 ton hub bolts also so make sure you get the right sized ones. If they dont have it on the shelf they can order it.
