spring lock connector pressure rating
Boss Hugg
Does anyone know what the pressure rating is for the spring lock connectors for edition fuel lines? Are they the same connectors they used for AC systems on, say, a 99 escort? I'm looking at a homemade AC system using the original heater box and just fabing an evaporator into the fresh air side. But I'm going to have trouble coming up with hoses. I'm wondering what kind of ends ill be able to find at the local hose and gasket shop.
Toddpole
I would think the easiest and most common connections would be -an/JIC/flare fittings. They're available in a wide range of sizes and variations and are extremely common facilitating easy repair/replacement.
Boss Hugg
Boss Hugg
Cool. I never put two and two together. Jic fittings are used on hydraulics so they've GOT to be good enough for ac...
broncodriver99
Glen Allen, VA
Not necessarily. The molecules of refrigerant are much much smaller than that of hydraulic fluid. While the fittings will no doubt take the pressure they may not seal well enough to prevent refrigerant leakage. Most all automotive AC systems use either flare or o-ring style fittings. Check with vintage air and the like for AC specific fittings. They aren't any more expensive then AN/JIC fittings and are designed to work for that specific purpose.
Ourobos
Big Island Hawaii
I've ran 60 psi on them no problem.. Not sure the max. rating though. If for fuel and EFI, you shouldn't see much over 40.
Boss Hugg
Boss Hugg
I'm definitely talking about A/C usage. Gonna put an evaporator from a 99 escort on it which uses spring lock connections, but I was looking at some different condensors. The trouble I always have in AC work is that the condensor never seems to be big enough to cool the air at idle. New vehicles, reworked vehicles, it doesn't matter. Troubleshooting always leads me to believe the condensor is not flowing enough air. So I want to put the biggest condensor possible on it, and considering the lack of inner fenders and such, and 3" BL on mine, it shouldn't be problem.
Here's a part of my project. http://youtu.be/QAawc-k9ByE
Steve83
A common EFI pump is rated to dead-head over 100psi, so the lines have to be built with a safety margin above that.
But an A/C compressor can dead-head above 450psi... Use the right fittings; not only because they're right, but because you may not be the only person to ever work on the truck, so others need to be able to distinguish what's inside those lines. You can cut the factory swages off a JY A/C line, then put the fitting with a new swage collar onto your custom hoses. Many aftermarket kits come with cheap fittings that have to be swaged - just swap to better JY fittings.
