Bundy
- Jan 10, 2009
- 2,045
I know that square bore has about the same size primary and secondary venturis whereas the speadbore/quadrajet have smaller primaries and larger secondaries. Can you run a speadbore on a squarebore manifold without an adapter? I ask because in trying to figure out my vacuum leak, I sprayed starter fluid around the base of the carb and the rpms picked up and in removing the carb I am wondering if I have the correct carb/intake.
My carb is a Carter 9605S Comp Series, which from what I read online is the similar to an Edelbrock 1407. I also have an edelbrock performer intake.
The carter carb is a quadrajet, right? Is my intake correct for a spreadbore??
