71massbronco
- Mar 13, 2011
- 1,321
I am not an avid engine guy, so I need some help in this department.
I have an engine that has been sitting since early 1990's maybe even the late 80's. After refitting the engine with new rotor, wires, coil, cap, and plugs, drained what little oil was left, put in fresh, then Murphy's n(Marvel, I meant) Mystery in the cylinders and let it set, turning it after a week of marinating to make sure the motor wasn't seized. It turned over over no problem.
I cleaned the carb and shot some cleaner down the throat. New fuel filter.
I also disconnected fuel line from the tank, and ran a new line into a five gallon gas can, as I didn't want to risk sucking something(s) into the carb from the old tank.
So after trying to get it to start, I checked to see if any gas was reaching the carb. It was dry.
My question is, should I have primed the fuel line (I didn't) and what steps should I take in trying to get the truck to start with an external gas tank line. All advice and tips are appreciated.
