Finally at that stage of firing up after rewiring my 66. Used a ron Francis
universal kit; added pertronix and pertronix coil. Turn key to what seems to be the on position, and use a remote starter. Engine turns over, seems to fire, but when I release trigger on starter she dies. Same with key start, key to start, engine fires and runs, but key does not return to on, starter keeps running so I have to turn switch to off.
Is this an ignition switch problem, or a wiring problem? When the battery cables are not hooked up the key turns to start, and although a little sticky,
it does seem to spring back to an open position. When I hook the battery cables back up, the ingition process seems to go from off to start, with no
return to the on position.
Thanks for any advice.
