mortimersnerd
- Aug 25, 2010
- 743
I'm having an odd and worsening issue with starting. The first start of the day usually takes a little more work, but is OK. If I shut it off, then try to restart I have to run the starter for a many seconds (15-20?) while trying to rev the engine up over 1500-2000rpm. If I can get it revved up and keep it there for a bit the truck runs totally normally. This AM, I pulled the truck out of the garage, then shut it off in the driveway. When I got back in it would rev, but died as soon as I stopped running the starter. The problem has started since I redid my fuel lines with steel. They're run outside the frame rail and are well away from all the exhaust components, and I'm pretty sure it's not vapor lock because it doesn't seem to be temperature dependent. One theory from a friend is that some crud from the new lines is holding the float open a little and making the engine flood a little when the engine is starting. Any ideas about where to start?
