I am pleased with the STC top with exception of the rear panel. I have a big stiff adjustable bar from roll bar to windshield, and I measured the distance stated in the direction (either 83 or 84" I don't have the directions near me now), and too loose, it comes loose, tight it comes loose, and finally I have to simply ask: The sides have a plastic strip that goes under the alumin bracketry to securely hold, but the rear panel does not, it is merely a thin material strip and it works loose, no matter how tight or how loose.
Bottom line, this rear panel is no good with the rear panel down, it comes loose. I keep mine rolled up as much as possible or in the boot, with top down. Or removed and stored away.
Any comments on the design?
Wayne
