Steering bell assembly removal
RenoBuc
Reno, NV
I need to replace the boot that attaches to the bell at the end of the steering shaft. I've loosened the clamps and am able to slide the shaft away from the box, but how does the bell-joint come off. Thought I might ask prior to taking a BFH to it...... Thanks for your help.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
There is a snap ring around the edge of the wide part of the bell. Take the snap ring out and the bell should slide off the end of the shaft. Be forewarned that it is full of grease and will make a huge mess on anything it comes in contact with.
Here is a picture of one that has been taken apart (or rather not put together)
http://www.wildhorses4x4.com/product/Manual_steering_box_boot_kit/Steering_Shafts
R
RenoBuc
Reno, NV
Yea, got the part about the grease...thats why it is getting replaced. Now how do I get the new boot on? Dumb question, but how do I get the bell/rag joint off or do I have to loosen the steering column, remove the wheel and slide the entire steering rod out the bottom? Thanks.
