I'd like to get rid of all the 3-on-the-tree related shifter components on my 72 column. I'd also like to rebuid the column w/ new bearings and bushings.
The column is totally out. It appears the bottom retainer doesn't come off. Seems to be crimped on. Is this correct? Does the lower bearing have to be removed from the top? How do the lower shift ears come out?
Also, I'd like to replace the upper collar with one that doesn't have the shifter knob. I already have the collar. It looks like the only way to remove it is to cut the column wiring. Correct?
