Brent13
Folks,
I am in the process of removing my dash for an install of a Painless wiring harness. I thought I could get dash out without removing column, but believe I was wrong. I have a Toms Family Cage, and there is just not enough room. I have the dash free, but don't think I can get it out. Can someone explain to me the easiest method to get the column out? Would like to tear it down minimally to get it out, obviously. Looking at it from under hood, but can't tell where to split it. If i do it at the rag joint, will the rag joint go thru the firewall. And Bronco is auto, C4, how does that shift linkage separate? I believe if I get column out, dash will come out easy, and go back in with minimal effort.
Thank You
Thank You
