mag409
I had new balljoints pressed into my knuckles and installed one side tonight. I read the manual and followed the procedure. Using a puller I pressed the knuckles in place and tightened the lower nut to 80 Ft-Lbs. Then went to the upper balljoint and set the adjusting sleeve to 40 Ft-Lbs. Nest I tightened the upper nut to 100 Ft-lbs and then rotated it forward to match up with the cotter key hole. I cant find my scale right now but I know I have more then the reccomended max of 26 lbs resistance on turning the knuckle. The manual says to toss the balljoints if this is the case. What is the danger of running this a little tight and also cant I just take it apart and restart the procedure?
