Jeff76
76 Bronco recently added 2.5 inch lift (new JBG springs/shocks all around) and new 'T' linkage / adj track bar from TBP. The new linkage required a change to a '75 pitman arm, which is a solid used stock OEM model. New stock rubber bushings. Toe In set in spec at 5/32" In. After explaining to the alignment shop that, while they cannot change the caster, I needed the reading, they did not take the reading, so I will have to take it back to get that another day.
I have purchased parts for new ball joints and hub bearings, but have not pulled / replaced them yet.
The driving result is a really tight fun to drive truck, up to around 45-50 mph, where it gets a little tricky. It was very tricky until I adjusted the tire pressure down from the POs 35psi to a more reasonable 28 PSI all around. Now it tracks pretty straight, slowly 'returns to center', about a 1" 'float' in the stock steering wheel at speed, but I always remember that even when driving new EBs back in the '70s with stock height suspensions and linkages. It exhibits some symptoms of bumpsteer at slow speed, but gets more dramatic at speed, to the point I'm not satisfied that my wife or 15year old could take it out on the road. The truck does have the mega 1" spacers on the front hubs (the kind with their own wheel studs)because of the Ford Truck wheel back spacing.
My plan is to:
1) rework the hubs / ball joints (not optimistic this will have an effect - very little movement in them now, but they are still unknown from the 2 previous owners of the truck, and may be the 36 year old original parts)
2) Try to find a way to make the adjustable track bar and the drag link more parallel.
I originally stuck with an OEM style pitman arm, because as you can see from the pictures, the pittman and the top track bar mount are very close to the same height. But that still leaves the linkages a bit skew. I am thinking that a slight drop of the pittman on the order of 2" would make the track and drag links close to parallel, but most of the drop pitmans I can find are 4" drop, and I think one from BC Broncos is either 3" or 3.5". I am concerned that too much drop in the pitmann will just cause bump steer in the opposite direction.
Looking for thoughts, ideas, opinions, and they are greatly appreciated!
Jeff
My plan is to:
Jeff
