Can an original steering wheel w/ half moon along with the OEM auto shift lever, turn signal lever and gear indicator mount on a ididit or Flaming Rivers tilt column?
Just looked at their site, I'm seeing "ididit" and also some custom tilt columns that WH teamed up with ididit to create. Is the one you mentioned the custom?
Thanks!
Thanks!
You can use a chevy column with a couple of minor modifications. It gives you the locking steering wheel with the key in the column. I used a truck column from 1985 or so.
... I've put in 2..... 78 & 79 Ford tilts. Both my ford have broke the tilt gear track. I'd been thinking about putting in an IdidIt....But I might want to check out these WH. Columns ..
.. An a 2nd thing I've not liked about the 78 & 79 ford column into my Bronco .. the wheel will drop between my knees but won't raise but a couple of click over straight .
.. I need the steering wheel to tilt up to the wind shield.
