ssray
So I’ve been looking through the many threads on Sterlings and have found lots of good info. Still a flew things I’m not sure about. I would like to narrow which I know makes for a lot of extra work, I’d just don’t really want the full width. It does involve a lot for not a whole lot of difference in width, I realize.
I found you can’t re-spline the axles as they are necked up at the spline, but is it possible to cut the outer end and bore and turn the flange to realign and weld it back to the axle. I just don’t know what alloy these are made of to even make this possible. Another thing would be a turned surface for a seal on the outer end of the housing? Simple operation on the lathe if there’s enough material there.
There are a couple of Ford dealers I’ve seen selling the stock lockers for under $500 if that’s a legit deal? I would probably look for a 2nd generation axle for the better pinion and would likely have to put gears in short of being lucky in whats out there. Which I’m also not current on. Some older posts suggested sterlings were easy to come up with and fairly inexpensive at the yards. Is that still the case or have they gotten scarce and more expensive?
They do have OX lockers available for the Sterling and I actually like the looks of it and your choice of actuating the locker. The downside would be shaving is likely out of the question as the OX has its own cover because of the shift fork etc. built into the case.
I’m probably not gonna be a all out rock crawler with this Bronc, but am looking at 37”/38” shoes and just want something reliable with those in mind. Planning on doing 4 link if my brain gets along with the spreadsheet and such. So there will be a truss mount involved which would take care of the spun axle tube possibility the Sterlings supposedly have.
Thanks for any current thoughts or comments!
Scott
Scott
