The housing that the plate resides in was rusted in the bottom, so the plate pretty much fell out the bottom.
I can make a new one and repair and weld up the housing.
This is one section of rust that kinda worked out in my favor.
both of my door striker screws were stripped on both doors. I had to drill the screws out. I bought new mounting plates for the backside and new screws. I found it to be a pain when it came to the drilling out of the screws. the drivers side was a bit of a challenge. if you only have the rear tank then it won't be.
I have nuts on the back side of one that I had to drill out. If I reach up as far as I can with a ratchet wrench I only lose a little (ok kind of a lot) skin getting it tightened back up as they loosen up from having to slam the door from the replacement rubber being so stupid tight.
I'll eventually take the new one out the bag on my bench and replace it someday.
