Hi all,
I'm looking to replace the aluminum aftermarket wheels from the PO with some stock looking steelies. I'm pretty sure I know the look I want, but I feel like I've gotten to the end of the internet and not found them. Not sure if a build from a place like Stockton Wheel is the answer, so hopefully you all can point me in the right direction.
Current wheel is 15x8 with a 3.625 backspace (90% sure, it could be a 3.5). I'm measuring backspace from the outermost of the inside edge of the wheel to the mounting surface using the spare tire. I get a smidge under 3 11/16 to as I move a block of wood around the rim, so I’m going with a 3 5/8 measurement. If I measure from just inside the outermost lip when the wheel inside ”flattens” out a bit, I get 3.5 (like measuring the wheel width and diameter). I’m somewhat obsessing about this measurement because the 1977 front end knuckle just barely clears the current wheel. In fact, in an area it looks like it is inside the wheel and would contact if it was a 14 inch wheel (hope that makes sense). So I think I need something with a 3.5 back space. Tires are 32x11.5R15 BFG A/T. I want the same look/stance with the new wheels, so am keeping the same size tire and wheel combination.
I do not want to go to stock steelies because I want the option for smaller (7, 7.5, or 8.125 inch) hubcaps--inspired by attached photo of an ICON Bronco with small caps. I think the Stroppe steel wheels had the inside cap tabs for the smaller caps, and those wheels also have a deeper look to them (less backspace?). I cannot find a new wheel that mimics this, and other wheels that are close do not have the backspace I need. I could do a reverse OE steelie from wheelvintiques and probably get what I’m looking for, but wanted to check with you pros.
I plan to paint (powdercoat?) the wheel to match the white top of my two tone. It’s Ford “Ultra white” and not wimbledon.
1. Am I measuring backspace right, and it is the very outermost edge as the “datum”?
2. Any 15x8 stock steelies with small hubcap tabs out there?
3. Is there a reproduction of the Stroppe steelies?
Thanks for the help guys.
Brett
Brett
