Synthetic Brake / Power Steering Fluid
sykanr0ng
PS Pump - Hydroboost - PS Box- Filter - Cooler - Reservoir - back to PS Pump and go around all over again
Correction:
PS Pump - Hydroboost: where it splits, a small amount powers the brake boost then returns to the reservoir and most flows to the PS Box- Filter - Cooler - Reservoir - back to PS Pump and go around all over again.
This is why the hydroboost unit has one inlet and two outlet ports.
74 Bronco Billy
74 Bronco Billy
Correction:
I gotta find me a diagram with the hydroboost in it. Sounds to me like you want the filter - cooler after the PS box since that is where the majority of the work load on the system (i.e. HEAT produced) will be. And since I am running a Ram assist, after the PS Box makes even more sense since the Ram Hydraulic Lines go in and out of the PS Box. Have I got this correct?
Thanks a lot for helping me with this.
Forrest:cool:
sykanr0ng
Forrest:cool:
Yes, the steering box (and ram if you have one) add the most heat.
Since the hydroboost unit itself uses only a little fluid it adds very little heat to the fluid, the fluid it uses can return to the reservoir without going through the cooler.
74 Bronco Billy
74 Bronco Billy
Its the splits and returns that have me all confused. I have the dual return Extreme duty pump and I have WH reservoir, but I also bought BC's filter. I have too many options on how to run the lines back....%)
